    • Unanswered topics
    • Active topics
What i must do to show signal strength in progdvb for rebel KOM1060 (Astrometa usb) usb stick?
rocklee
rocklee
Sun Dec 26, 2021 4:10 pm
#1 by rocklee
I have legal progdvb pro and windows 10. What i must do to unlock signal strength?
  • Wed Dec 29, 2021 6:32 pm
Re: What i must do to show signal strength in progdvb for rebel KOM1060 (Astrometa usb) usb stick?
This is most depended from driver. ProgDVB only take value from driver and show in interface.
Do you have problem with signal level (playback of channels?)
  • Thu Dec 30, 2021 5:13 pm
rocklee
rocklee
#3 by rocklee
Sometimes yes, because signal quality have 80+ but sometimes program have a lot graphics artefact like have not much signal strength and watching tv is not good
  • Sat Jan 01, 2022 3:55 pm
#4 by Prog
Impossible fix that on software level. Need need antenna or some amplifier.
  • Sat Jan 01, 2022 5:22 pm
rocklee
rocklee
#5 by rocklee
I have normal antena, but sometimes progdvb in my computer crashed. Where i can find log what make those problem?
  • Sat Jan 01, 2022 7:08 pm
#6 by Prog
If you have artifacts then antenna not good for this tuner. May be good for other tuner but not for Astrameta.
but you can try BDA options in ProgDVB (Settings->[device name]). For example MS demux using.
  • Mon Jan 03, 2022 12:18 pm
rocklee
rocklee
#7 by rocklee
time: 3.1.2022 19:44:36
Type: Crash in unmanaged part
Module: C:\Program Files (x86)\ProgDVB Professional\ProgDvbEngine.DLL
Thread: 0x2aa8
in logs i have this problem (when progdvb crashed). What solution i must do?
  • Mon Jan 03, 2022 6:47 pm
#8 by Prog
You can try change demux in Options->Playback. But bad traffic (on bad signal) is crash test for app. Crashes are possible.
  • Wed Jan 05, 2022 6:06 am
rocklee
rocklee
#9 by rocklee
K i change but this i have:
time: 6.1.2022 17:15:22
Module: C:\Program Files (x86)\ProgDVB Professional\ProgDvbNet.exe
Thread: 0x4f38
I have crash after ~5-6 min when i start watch tv
  • Thu Jan 06, 2022 6:48 pm
#10 by Prog
Please enable logs and send me all files from Logs folder after next crash.
  • Thu Jan 06, 2022 6:51 pm
  • It is currently Sun Jun 15, 2025 11:45 am
