    • Unanswered topics
    • Active topics
Recording to SMB/LAN Recording on a PC
ravo1957
ravo1957
Thu May 20, 2021 3:29 pm
#1 by ravo1957
Hi is it possible to Set up SMB/LAN Recording on a PC with progtv for android
  • Wed Feb 23, 2022 7:19 pm
Re: Recording to SMB/LAN Recording on a PC
I am not test that. ProgTV not working with SMB or FS directly. I think if android support that then possible in ProgTV also.
  • Thu Feb 24, 2022 5:33 am
ravo1957
ravo1957
#3 by ravo1957
OK no problem, i was just curios, i think some android versions do support it though.
  • Thu Feb 24, 2022 3:54 pm
#4 by Prog
I am found some libs for support of smb. May be try use one in future versions.
  • Thu Feb 24, 2022 4:43 pm
ravo1957
ravo1957
#5 by ravo1957
sorry but what are libs?
  • Fri Feb 25, 2022 4:00 pm
Return to “ProgTV Android”
  • It is currently Sun Jun 15, 2025 12:13 pm
