    • Unanswered topics
    • Active topics
GitHub m3u playlist-Is it possible to add it
Re: GitHub m3u playlist-Is it possible to add it
#1 by Prog
What channel not working?
  • Sat Apr 02, 2022 6:37 am
ProgDVB more power player then ProgTV Android and can open more links.
Please send me logs. I am test 3-4 channels from you list (in ProgDVB) and all channels are working.
  • Sat Apr 02, 2022 3:00 pm
#3 by Prog
No any problems on my PC. Check firewall settings and check link again
  • Sat Apr 02, 2022 6:34 pm
#4 by Prog
"https://iptv-org.github.io/ipt/index.m3u" link is bad
  • Sat Apr 02, 2022 7:39 pm
#5 by Prog
In log not correct link.
  • Sun Apr 03, 2022 6:41 am
#6 by Prog
Try change user agent. May be server not give access to ProgDVB.
  • Sun Apr 03, 2022 4:07 pm
#7 by Prog
But again. this is working on my PC in ProgDVB
#8 by Prog
In iptv client. same place when you enter url.
  • Mon Apr 04, 2022 11:17 am
#9 by Prog
On my PC ProgDVB working fine also...
  • Mon Apr 04, 2022 2:55 pm
Return to “IPTV”
  • It is currently Sun Jun 15, 2025 1:46 am
