Hi admin, hi everyone,
I have try your softwareProgDVB but not working.
problem: i have no signal at all.
pc: i have a P4. enough DDR memory. XP pro with pack 2.
i have skystar2 installed with latest drivers.
i have dish that works in my stand alone receiver. hotbird+astra.
i plugged only hotbird cable to my card. so no DISEcQ.
Here what i've done:
I tried to setup both. progDVB and setup4pc. setup4pc is red. no signal.
i tried to scan channels but no channel at all (wich is normal coz no signal)
please help me coz its so exciting to have a dish+pc sat card and very frustrating not being able to use it at all.
(i tried to search in forums and now..im just disasperate..)
suggestions?[/img]
enableing
#2When i first installed my skystar 2 it worked ok,then i switched my computer off,when i started it up the next day,the signal for setup4pc was red,i had to go into device manager and enable the card.For some reason the card had switched to disabled,it has never done it again.
regards.dishrigger
regards.dishrigger
i wish my dish was bigger lol.
amd 3400+/512 ram/128 of for inbuilt graphics/xp home sp2 updated.
Loads of standalone tv/sat/radio/antennas/amps/filters,ive collected over the last 40 years.
