    • Unanswered topics
    • Active topics
ProDvb for PC win 10 i5 sandy bridge old motherboard
ivtec
ivtec
Fri Nov 24, 2017 7:32 pm
#1 by ivtec
Hi dear prog, i've been using your Prog DVB Network Edition for x64 OS*
version 7.48.1, and notice that some times it takes too long to open or some time freezes loading on start up ,i wonder if it's because of my older hardware ? should i use an older version, and which one should i try? thanks
  • Sun Nov 13, 2022 5:31 pm
Re: ProDvb for PC win 10 i5 sandy bridge old motherboard
CPU load most depended from video codec. And I5 not bad CPU for most channels.
Please send me logs of long start of channel.
  • Sun Nov 13, 2022 5:41 pm
ivtec
ivtec
#3 by ivtec
Sorry mate i don't know how to do that, please give instructions? thanks.
  • Sun Nov 13, 2022 6:05 pm
ivtec
ivtec
#4 by ivtec
Hi mate, i was able to fix with a few uninstal
l and reinstalls, also ,how i get rid of this every time i open player?
  • Mon Nov 14, 2022 9:57 pm
#5 by Prog
You must setup IPTV Client or disable it TV sources.
  • Tue Nov 15, 2022 6:05 am
Return to “IPTV”
  • It is currently Sun Jun 15, 2025 1:48 am
