    • Unanswered topics
    • Active topics
New version at player ProgrDVB crush when I add plugin
crissty87
crissty87
Sun Nov 13, 2022 7:41 pm
#1 by crissty87
Hello ,
I install new version off program but after I add "Plugin " folders in main folder , player crush . What can I do to use plugin in new version at player ProgrDVB?
Thank you
  • Fri Nov 18, 2022 9:20 pm
Re: New version at player ProgrDVB crush when I add plugin
Please zip and send me plugins folder. I am not can repeat crash.
x32?
  • Sat Nov 19, 2022 7:05 am
crissty87
crissty87
#3 by crissty87
x64 . I can t send you,to large files . 6.83 mb have zip file
  • Sat Nov 19, 2022 9:33 am
#4 by Prog
For x64 ProgDVB must have x64 version of plugin
  • Sat Nov 19, 2022 9:40 am
crissty87
crissty87
#5 by crissty87
My plugin are for x64 .Before update,my plugin works.I use now same plugin like before.Can you sen me other plugin for try ?
  • Sat Nov 19, 2022 9:42 am
#6 by Prog
Hm. Must working. Please send me this zip on email. Or link to zip
  • Sat Nov 19, 2022 9:51 am
crissty87
crissty87
#7 by crissty87
sent at prog@progdvb.com
  • Sat Nov 19, 2022 10:07 am
  • It is currently Sat Jun 14, 2025 3:05 pm
