Dear Users,
I've a problem with my TechnoTrend TT-Connect C-1200 USB Box. With the normal TechnoTrend Software I can find all channels and can see them in best quality. But by using ProgDVB I can't find a channel.
Does anybody had the same problem and can help me?
Which driver is the best and which device I must choose in ProgDVB?
Thanks a lot!
Freddy
hi , then you need a proper transponder .ini that fits to the frequencies of your kabel provider...With the normal TechnoTrend Software I can find all channels and can see them in best quality. But by using ProgDVB I can't find a channel.
budget-usb-boxwhich device I must choose in ProgDVB?
But i´m not 100% sure that this box really works with progdvb...
I have the same problem like Freddy99. I have checked my transponder.ini. No misstake. Progdvb show only 100 % level but no quality.
