I am not able to view HDTV programs like prosieben HD with BDA drivers and progdvb 5.09 ?
The scheduler does also not work. is this a known bug ?
relictEPG 0.66.3 plugin does not work with progdvb 5.09 because internal EPG is not deselectable ? Will it be usable in future versions ?
Cheers,
theo_tusch
This card use the same driver model as the hvr 4000...with both cards its not possible to receive H.264 DVB-S 2 channels...I am not able to view HDTV programs like prosieben HD with BDA drivers and progdvb 5.09 ?
viewtopic.php?p=4122#4122The scheduler does also not work. is this a known bug ?
only prog knows this...relictEPG 0.66.3 plugin does not work with progdvb 5.09 because internal EPG is not deselectable ? Will it be usable in future versions ?
p.s. progdvb 5.xx is still a test version..
