ProgTV Android crashes and iptv service keeps buffering
  • 1
  • 2
ravo1957
ravo1957
Thu May 20, 2021 3:29 pm
#1 by ravo1957
Hi for the past few weeks the app has stopped at least once a day even after the updates, also the iptv service i use is buffering a lot but plays fine in other apps
  • Sun Apr 02, 2023 9:22 pm
Re: ProgTV Android crashes and iptv service keeps buffering
What last good version?
Can you give me link for test?
  • Mon Apr 03, 2023 7:22 am
ravo1957
ravo1957
#3 by ravo1957
Hi sorry can't remember which version it was before the problem started, but i think it was at least 3 versions ago. How do i give you the link to test?
  • Mon Apr 03, 2023 4:55 pm
#4 by Prog
Link of channel. What source of TV you use?
  • Mon Apr 03, 2023 6:11 pm
ravo1957
ravo1957
#5 by ravo1957
Do you mean my iptv provider?. That is the BritishTV club it's a M3u file
  • Mon Apr 03, 2023 8:47 pm
#6 by Prog
Can you give link of channel from this m3u? Or m3u file and name of channel for test.
  • Tue Apr 04, 2023 6:02 am
ravo1957
ravo1957
#7 by ravo1957
Hi It's not just one channel, it's 4 or 5. I am not supposed to give you my m3u file as it has my login details in it.
  • Tue Apr 04, 2023 5:38 pm
#8 by Prog
I will inform you in this forum when there will be a test version.
  • Tue Apr 04, 2023 7:38 pm
ravo1957
ravo1957
#9 by ravo1957
OK thanks. Any idea when that will be?
  • Tue Apr 04, 2023 7:51 pm
ravo1957
ravo1957
#10 by ravo1957
It's still crashing after the last update, twice on Tuesday and twice yesterday
  • Thu May 04, 2023 2:51 pm
#11 by Prog
Please send me logs after crash
  • Thu May 04, 2023 3:26 pm
ravo1957
ravo1957
#12 by ravo1957
Hi how do i send you the logs? i have copied them off the tv box on to my pc.
  • Fri May 05, 2023 12:08 am
ravo1957
ravo1957
#13 by ravo1957
I have sent you the logs
  • Fri May 05, 2023 5:31 pm
#14 by Prog
Do you send me on email? Not received.
  • Fri May 05, 2023 7:21 pm
ravo1957
ravo1957
#15 by ravo1957
i sent them in a PM
  • Fri May 05, 2023 8:01 pm
  • 1
  • 2
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 4:48 am
