by Juergen
With that multiswitch alone, things are very limited.
Try to look to the dish, if it has one LNB with four cables on it, or two LNBs with two cables each.
First situation would mean, Astra only, but standard settings and full access to all of that bird system.
If so, don't add a switch in LNB settings, just set DiSEqC to none and set one LNB with properties adjusted to Astra 19.2°E, all details to default.
Second situation would surely mean, only LowBand of Astra and Hotbird, position switched by 22kHz.
This was normal in analog ages, but still allows access to parts of the digital transmissions.
LOF 1 used only, may either be 9750 MHz or 10000MHz (on a terribly old LNB), seperately for each LNB.
Set switch value to LOF1 + 2150 MHz, to get as much as possible, by extending the LowBand to the maximum.
If so, set a DiSEqC 1.0 switch, change it's properties to '2 ports switch by 22kHz', set the first LNB to Astra, second to Hotbird. If no success at all, set LNBs the other way around.
Best would be to ask another user or the owner of the dish set, if you still don't succeed on your own, perhaps some wird special settings are necessary.
Both cases, no DiSEqC at all.
22kHz band switching, if used, is NOT visible in DiSEqC settings, as it manages the LOF switching thewn, as part of one / each universal LNB.
But if 22kHz is used for position switching, you would always use LOF1 only, add a 22kHz position switch as mentioned above.
Once more, LNB / DiSEqC settings must be a true image of the existing hardware setup. This is important, as DVB tuners tehnically don't get any information on what's coming down the roof, you have to teach them the truth...
