Microsoft Defender SmartScreen prevented an unrecognised app from starting
masheee
masheee
Mon Mar 28, 2022 9:42 pm
#1 by masheee
When trying to install newest version, I get the above message, is safe to run?
  • Thu Aug 15, 2024 7:21 pm
Re: Microsoft Defender SmartScreen prevented an unrecognised app from starting
Yes. Used new code sign certificate and possible some warring messages.
  • Fri Aug 16, 2024 7:10 am
masheee
masheee
#3 by masheee
Thanks, do you plan to fix this?
  • Sun Nov 03, 2024 8:42 pm
#4 by Prog
This should cure itself as Defender updates. It does not depend on the application. Maybe my signature is not the most expensive provider.
I hope you took the installer from my site?
ps: You can check https://www.virustotal.com/gui/home/upload if a virus is suspected
  • Mon Nov 04, 2024 7:13 am
Email sent.
  • It is currently Sat Jul 25, 2026 11:49 pm
