Re: Crash after Record
Fri Oct 04, 2024 8:37 pm
Check record folder. Please enable logs and send me after next crash.
Thank you very much for your quick reply.
The output file is created correctly.
The administrator has full rights in the output folder.
Please find attached the log file.
Thank you very much.
ProgLogs.zip
Hopefully it helps.
(521.68 KiB) Downloaded 423 times
