    • Unanswered topics
    • Active topics
Difference between ProgTV 3.6.0 and ProgTV 7.65.3
NickyNSS
NickyNSS
Sun Feb 09, 2025 8:07 pm
#1 by NickyNSS
Hello,
What is the difference between the stand alone ProgTV 3.6.0 and the ProgTV from the package ProgDVB+ProgTV 7.65.3?
Can both be installed together on one PC?
Thanks
  • Mon Feb 24, 2025 9:01 pm
Re: Difference between ProgTV 3.6.0 and ProgTV 7.65.3
7.65.3 is version of ProgDVB. Version of ProgTV is 2.x. You can install both on same PC and test without problem.
  • Tue Feb 25, 2025 6:14 am
NickyNSS
NickyNSS
#3 by NickyNSS
Thanks 👍
  • Tue Feb 25, 2025 6:37 am
Return to “ProgTV Windows”
  • It is currently Sun Jun 15, 2025 12:18 pm
