Is it possible to save a show that is currently stored in archive (catch up)?
Batesta
Batesta
Fri Mar 21, 2025 12:38 pm
#1 by Batesta
Essentially the title. I want to store on my hard drive a show that is still available on catchup archive but don't know how. Thanks!
  • Fri Mar 21, 2025 12:39 pm
Re: Is it possible to save a show that is currently stored in archive (catch up)?
You can open and use record function. Or Service->Record clips->...
  • Fri Mar 21, 2025 2:19 pm
Batesta
Batesta
#3 by Batesta
Yes but that way I'll have to watch the whole thing, instead of just downloading it. Shouldn't it be possible to just download without having to record it?
  • Fri Mar 21, 2025 5:59 pm
#4 by Prog
Background recording in context menu of channel.
But not special function for recording from archive. In my plan.
  • Fri Mar 21, 2025 6:08 pm
Batesta
Batesta
#5 by Batesta
Also, doing your suggestion works, but windows keeps making an error noise all the way through which is annoying (but it works)
  • Fri Mar 21, 2025 6:21 pm
Email sent.
  • It is currently Sat Jul 25, 2026 11:47 pm
