ProgDVB X64 Windows No StreamReader Drivers For TBS6903x
BabaDem
BabaDem
Tue Aug 08, 2023 7:00 pm
#1 by BabaDem
I installed ProgDVB Professional X64 for Windows, I'm using Win 11. I noticed there is no compatible Device modules, llike StreamReader drivers available for the TBS6903X card. When I assign the "{BDA} TBS 6903x DVBS/S2" drivers and do a "Blind Search" the program Crashes and closes. How do i get this to work correctly?
  • Wed Apr 30, 2025 5:05 am
BabaDem
BabaDem
Re: ProgDVB X64 Windows No StreamReader Drivers For TBS6903x
#2 by BabaDem
No update on this? :(
  • Thu May 01, 2025 12:04 am
#3 by Prog
Do you mean crash in x64? StreamReader does it better. API for blind scanning is not official and has complexities for different TBS devices
  • Thu May 01, 2025 5:54 am
BabaDem
BabaDem
#4 by BabaDem
Yes, It crashes and if you add SreamReader Files to the Modules folder, it doesn't appear as an option during Hardware setup.
  • Thu May 01, 2025 7:37 pm
#5 by Prog
What you mean Hardware setup? You must select Stream reader in TV Sources of ProgDVB. Of course need x86 version of ProgDVB.
  • Fri May 02, 2025 5:54 am
BabaDem
BabaDem
#6 by BabaDem
I get it now. So StreamReader is only available in x86 version.
That brings me to this question, how do you import scanned transponder list from EBSPro or CrazyScan into ProgDVB?
  • Fri May 02, 2025 6:36 pm
#7 by Prog
What format? Please send me sample of list.
  • Fri May 02, 2025 6:42 pm
BabaDem
BabaDem
#8 by BabaDem
I mean a *.ini file like the attached document.
2710.rar
Scanned transponders
(183 Bytes) Downloaded 526 times
  • Sun May 04, 2025 7:47 pm
#9 by Prog
Put this file to Transponders folder. I am not test this case every day but must work.
  • Sun May 04, 2025 8:26 pm
Email sent.
  • It is currently Sat Jul 25, 2026 11:50 pm
