Problem scanning Channels ProgDVB x32 with TBS6903x
BabaDem
BabaDem
Tue Aug 08, 2023 7:00 pm
#1 by BabaDem
Using ProgDVB x32 with TBS6903x, am able to scan in Transponders on some Satellites, but unable to scan in and display the corresponding channels. I'm Using the latest Version of ProgDVB x32, ver. 7.66.3 and StreamReader drivers. Any reason why this could be happening and how can this issue to resolved?
  • Wed Apr 30, 2025 5:07 am
Re: Problem scanning Channels ProgDVB x32 with TBS6903x
Do you mean normal scanner or blind scan mode? Do you try BDA.device in place of StreamReader?
  • Wed Apr 30, 2025 6:09 am
#3 by Prog
btw, you can try modern version of StreamReader.dll from this site https://sourceforge.net/projects/crazyscan
  • Wed Apr 30, 2025 6:13 am
BabaDem
BabaDem
#4 by BabaDem
I mean Blind Scan mode. Using BDA device in place of StreamReader produces very weird symbol rates. For example, Frequency 4080 V 34286, 5/6 DVB-S2 16APSK, scans in as 4080 V -74629 16APSK 5/6. Note the negative SR value of -74629.
  • Wed Apr 30, 2025 9:49 pm
BabaDem
BabaDem
#5 by BabaDem
Yes, I used the latest StreamReader Release and there's no difference.
  • Wed Apr 30, 2025 9:51 pm
Email sent.
  • It is currently Sat Jul 25, 2026 11:45 pm
