    • Unanswered topics
    • Active topics
Change Audio Channel on TV
Doc
Doc
Mon Aug 27, 2007 12:00 pm
#1 by Doc
How can i change the audio stream on ProgDVB ?
I can choose only Stream 0.
  • Wed Aug 29, 2007 2:08 pm
SiLencer
SiLencer
Fri Nov 03, 2006 12:10 pm
#2 by SiLencer
Press update and apply in channel options ...if there are more then one audio pid ..you can choose them now...
  • Wed Aug 29, 2007 2:23 pm
Doc
Doc
#3 by Doc
thx
  • Wed Aug 29, 2007 2:31 pm
Re: Lib VLC Engine Pop Up
In prerelease fix of Engine mode. But this is not last update...
Prog, Tue Aug 05, 2025 9:22 pm
Re: The sound of voices in mo…
Hello. Do you use libvlc mode? You can try ProgDVB Engine also. Options->Playback->VOD = ProgDVB Engine. + You can try s
Prog, Tue Aug 05, 2025 5:27 pm
The sound of voices in movies.
Hello, I bought the ProgTV version and I have a problem, when I am in my movies section and I play one, the sound of the
ThePoGoBoY, Tue Aug 05, 2025 12:36 pm
Re: проблемма со звуком
А что за провайдер такой? Более чем странный подход. Скорее 25 лет как ТВ занимаюсь, в первый раз вижу. У меня не о
kostan, Mon Aug 04, 2025 3:13 pm
  • It is currently Wed Aug 06, 2025 5:04 am
