Hauppauge HVR 3000. it is compatible with progdvb?
1 post
UnlockerPT
UnlockerPT
Thu Aug 23, 2007 4:19 pm
#1 by UnlockerPT
hello
does anyone tried this card with progdvb on winXP and on WinVista?
Thanks
  • Fri Aug 31, 2007 8:53 am
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 12:38 pm
