Though I don't have much time these days, I've started testing your latest version here. I'm trying to go systematical and will keep it as precise and easy as possible.
Conditions as usual:
Win98SE, P III 800MHz @ i440BX
Nexus 2.2 (true) HW mode, driver 2.19h (non-KS)
Audio controls on DVB hardware
'receive mpeg2 from SS1' disabled
No 3rd party plugins
- new EPG Module only lists Now/Next
Still wrong data showing on all german (Astra 19.2) stations, just meaningless squares and question marks, structure points to wrong stream source...
Patched the wrong switch, it seems...
Tried the EPG module from 4.84.1w9x instead, no data shown at all.
- playback slider function is working again
But on filwe play, the tuner audio is not muted. Even the mute function only works for the file audio, the TV audio continues.
- playback does not work over the Nexus hardware TV out, there the tuner audio and video keeps active.
- PVA recordings aren't played anymore
- recording to PVA is not possible anymore, option is removed, TS introduced instead. But SS1 won't record TS. If selected, MPG is done instead.
English language file issue or a function change by purpose???
- on file play STOP does not work, file video disappears but file audio plays on. No tuner video after file play.
- on playback, the horizontal scaling is wrong, instead of 720 pixel it seems to scale to 768, adding black bars on the sides at (tue) 4:3 material and screen. I'm running 1280x960 (square pixels) here, on a 20" CRT.
Playback scaling error occurs both in window mode and full screen.
Software scaling option does not chamge this.
- most of my (new or old) recordings, that don't play on any version after 4.75w9x, make 4.86.5w9x crash badly, overlay is lost until system reboot.
I can't find a system behind that, perhaps it's a file header issue, as known from most ProgDVB .mpg recirdings for quite some time now...
- on first run of this version, I had to change to surface and back to overlay, to get an overlay picture. Radeon 7200/VE here, primary screen used.
Back to 4.75w9x for playback and 4.84.1w9x else...
Did not find the time to test on Win2k yet.
Best regards
Juergen
p.s.
- scanner issues:
After a full scan of Astra 19.2E, the german stations RTL Television, RTL2, ZDF DOKU, ZDF INFO and ZDF THEATERKANAL were falsely declared as scrambled, and the provider for those is set to CSAT, which is both completely wrong, of course. So this is a database error.
When scanning the RTL transponder alone, RTL Television and RTL2 turn to noname SID...
But the provider is scanned correctly as RTL World then.
Same with update from channel properties, provider correct, not scrambled, but no name found.
