Digitalrise DVB-C PCI CI and ProgDvb always crashes any Hint
1 post
amber0788
amber0788
Wed Oct 03, 2007 10:58 am
#1 by amber0788
Hi to all visitors of this forum
does anyone has a Digitalrise DVB-C PCI CI card and uses it whith ProgDvb
but both versions 4.*** 5.*** chrashes when i try to scan transponders.
I tried the driver from the delieverd cd and the new one from the site but both the same problem.
Maybe someone can help me.
amber0788
  • Wed Oct 03, 2007 11:06 am
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 12:52 pm
