TT-SS1 and ProgDVB 5.11
Hi,
I had no problem with ProgDVB 4.x but with the 5.x version I'm not able anymore to:
- EPG doesn't work anymore
- can't change channels using keypad (writing the number plus enter)
- memory leaks errors exiting the program
- very often fatal errors on startup, recover possible only deleting progdvb.ini
No plugin installed.
TT SS1 in hw mode.
Thanks,
Max
Keep in mind, 5.x and Engine2 versions are still declared as test versions.
Some functions are not implemented in Engine2 yet.
For daily use, I'm staying with 4.84.1 for zapping and recording and 4.75 for playback here, both on Win98SE and Win2k.
Just tested 5.11.2 ee, under XP SP2 with TT 2300S(soft mode), it is working correctly with all features (EPG, Scan, Scheduler,...) Its the first time that I can use 5.1x.x ee, last working for me has been 5.09.0 std (without scheduler)
The 5.11..2 pro is no more test, it is declared release, but I cant use my TT 3200 S2 (and Diseqc 1.0 4x1 switch) with ProgDVB, lost signal when changing TP/channel (S or S2). The same switch is working well with 2300 S.
The same S2 card and switch are working perfect with DVBViewer 3.9.
New TT BDA API is possible for ProgDVB, if Prog request it
