SP-400 no H.264 and AC3 Prog 4.88 and 5.12
toppa
toppa
Sat Nov 24, 2007 1:52 pm
#1 by toppa
:( Hi,
i bought prog and the elecard filters for 100€ für HDTV. But i did not work :-(
My config Vista Ultimate german. SP-400 with BDA Driver.
Only Asta HD works, but astra HD has no AC3.
Has somebody an idea? I have no Problems with ALTDVB, erverthing works.
thx
  • Mon Nov 26, 2007 12:54 pm
Is it problem with S2 transponder or h264 on DVB-S?
  • Thu Nov 29, 2007 7:01 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 11:38 am
