Dear all,
the programmed recording over EPG will not start. The entry inside the listing is deleted, but the file is not created.
What could be the problem?
I am usinf the standart edition.
Thanks for your kind help....
no record with scheduler
#3hi reklov2007,
I have the same problem with progDVB 5.12.10. It is not possible to use the scheduler, because it is not rocording the programmed movies. It is just lighting a red point in the progDVB-Icon in the systemtray.
With progDVB 4.77 its function.
Maybe you fixed it already. Please tell me.
regards
Horst
regards
Horst
That has been discussed here:
viewtopic.php?t=24&start=150
The new 'combined' scheduler command lacks a delay between channel change and start record. Split the commands manually.
Frank
Frank
GA965P; Core2Duo 2,1 Ghz; ATI 1600XT PCIe; 2Gb; TT Premium 1.3 moded, driver: TT 2.19h software mode; WinXP;
