hardware question?
1 post
wanlau
wanlau
Thu Dec 13, 2007 3:25 pm
hardware question?
#1 by wanlau
hello
I just want know if this card "Pinnacle PCTV DUAL SAT Pro PCI 4000i" is compatible with Progdvb.
thank for your reply
best regards
  • Thu Dec 13, 2007 3:30 pm
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 2:33 pm
