hauppauge hd s2 controller use in progdvb
1 post
ticker
ticker
Thu Dec 20, 2007 7:58 pm
#1 by ticker
how can i use the controller from the card to zapping the channels in progdvb ?
  • Fri Dec 28, 2007 9:47 pm
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 11:50 am
