    • Unanswered topics
    • Active topics
No HD Video. Audio Working when upraded to latest progdvb
DanishC
DanishC
Wed Jan 02, 2008 6:11 pm
#1 by DanishC
Hi Guys
For some reason after I upgraded to progdvb, my hd channels no longer work.
Audio comes in fine but there is no picture.
I've tried several different filter combinations and different video renderers but no cigar. I've also tried a fresh prog install in a different directory. SD channels come through fine.
Any help would be very much appreciated.
Thanks guys.
  • Wed Jan 02, 2008 6:14 pm
What version you use and what version last good?
  • Wed Jan 02, 2008 6:35 pm
DanishC
DanishC
#3 by DanishC
Currently using 5.12.6, the last good working version for me was 5.12.4. I skipped .5 all together.
Sorry should have included that info.
  • Wed Jan 02, 2008 6:44 pm
#4 by Prog
Hm. 5.12.6 must better then .4 ... what channel you test?
  • Wed Jan 02, 2008 8:05 pm
DanishC
DanishC
#5 by DanishC
For testing purposes I tested several Nimiq2 hd feeds. All produced the same results.
  • Wed Jan 02, 2008 8:15 pm
Re: Падает инсталлятор
Обновил пререлиз. Добавил доп строки в installation.log. Пришлите мне его если снова повиснет.
Prog, Sun Feb 01, 2026 7:18 am
Есть идея. Если при установке выключить регистрацию планировщика, которая включена по умолчанию. Не виснет?
Prog, Sun Feb 01, 2026 6:42 am
Русских буфк в пути нет? Имя аккаунта в винде из простых английских букв, одно слово, соответственно путь к профилю
f2065, Sat Jan 31, 2026 10:04 pm
Re: проблемма со звуком
Стоп. Проблема с aac или только с aac 5.1?
Prog, Sat Jan 31, 2026 5:48 pm
  • It is currently Wed Feb 11, 2026 11:39 am
