Hello there,
you may want to follow up this bug which is in the latest release of a licensed progdvb PRO 5.12.7 running Vista 32 bit US version latest patches installed.
Regards, Fobaar.
ee the end of this message for details on invoking
at ProgDvbNet.OSDChannelCaptionForm.timer1_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100)
ProgDvbNet
Assembly Version: 5.12.7.0
Win32 Version: 5.12.07
EngineApiWrapper
Assembly Version: 1.1.0.0
Win32 Version:
msvcm80
Assembly Version: 8.0.50727.762
Win32 Version: 8.00.50727.762
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.762_none_10b2f55f9bffb8f8/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.0.2
Win32 Version: 1.0.0.2
IPDev.Skins
Assembly Version: 1.2.7.0
Win32 Version: 1.2.7.0
ProgDvbNet.EPG
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
Accessibility
System.Design
Newest drivers for your dvb-card may help. I downloaded latest drivers for my SS2 (ver. 4.4.1) and now ProgDVB_PRO_5.12 works and exits correctly.
But I still have problems with this version of ProgDVB. Every 10-20 seconds video thread stops for a while (0.5 sec) and continues. I even replaced Elecard filter for an old one (that was in ProgDVB_4.22) but it didn't help. When I used ProgDVB_4.22 there was no such problem. Must also say that ProgDVB_4.77 also had that problem. Only old versions worked brilliantly.
Yes, it is a startup bug. And It also appear with v5.12.9 see below.
balabamaka, I already have the ss2 driver 4.4.1 and this bug has nothing to to with it as it is a null pointer assignement in the progdvb code.
Foobar
mscorlib
ProgDvbNet
Assembly Version: 5.12.9.0
Win32 Version: 5.12.09
EngineApiWrapper
Assembly Version: 1.1.0.2
Win32 Version:
msvcm80
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.1.0
Win32 Version: 1.0.1.0
IPDev.Skins
ProgDvbNet.EPG
Accessibility
System.Design
enabled.
For example:
<configuration>
</configuration>
Foobar
mscorlib
ProgDvbNet
EngineApiWrapper
Win32 Version:
msvcm80
System
System.Drawing
ProgDvbNet.bc
IPDev.Skins
ProgDvbNet.EPG
Accessibility
System.Design
enabled.
For example:
<configuration>
</configuration>
