Nvidia pure video decoder
Hi there,
i use ProgDVB 5.13 now und the Nvidia pure video decoder (last version of 1.02.223). If i set the nvidia decoder as my default decoder, the letter box is not correct shown on my display. I use a 24" LCD display and the letter box mode in ProgDVB is set to 16:10 (the monitor do support this wide screen format). There are black stripes on the right and left border so I have no classic full wide screen and the movies dont fill out my screen. Also no decoder properties are shown if i click with the right mouse button in the decoder properties icon which is in the systray.
If I change to elecard all works fine with the full wide sreen display (black strips are in the lower und upper side of the monitor as usual).
I have a Nvidia Ge-Force 7600 videocard with the latest forceware software installed.
How can I fix this problem ?
How can I configure the nvidia decoder ?
My system: Windows XP Professional
Thanks a lot
Chris
Re: Nvidia decoder
Try this
File ==> properties ==> video decoder ( double click ) ==> then u continue :D
OS : Win XP SP2
CPU : P4 Intel 3.00 GHz "HT"
Memory : 2 GB
DVB-S : Sky Star 2 (2.6D) ( 4.4.0 )
Hotbird 13.0°E | Badr-3/4 26.0°E | Nilesat 101/102 7.0°W
Re: Nvidia decoder
Frozen-Figo wrote:Try this
Hi,
MANY THANKS ! ! ! Your hint did help, have configured the nvidia decoder and now the right display on my screen ! :D :D :D
Thanks a lot and greetings
Chris
