ProgDvb does not record anymore from commandline (4.89.0.5) #1 by samoth Progdvb does not record anymore from commandline. If I use for example this commandline Code: Select allProgDVB /CH:"Das Erste" /StartRecord:"test.mpg" ProgDvb starts fine, switches to the right channel presses the record button, but the recording will not start. This works fine with ProgDVB version 4.85.1 which I have used before. Best regards Samoth QuoteSat Feb 23, 2008 3:05 pm
. #2 by Prog Current version support only one command You must use like ProgDVB.exe /ch:"fashion" ProgDVB.exe /record QuoteSat Feb 23, 2008 3:15 pm
#3 by samoth Oh, that´s really sad. Because I´m am using windows scheduler for recording. Then I have to switch back to the old version. Will this be fixed in a future version ? Best regards and thank you very much for your nice program. Samoth QuoteSat Feb 23, 2008 3:22 pm
