K-World VS-DVB-S 300U?
daddydiegs
daddydiegs
Mon Mar 03, 2008 3:27 pm
Phil
Contact:
  • Yahoo Messenger
#1 by daddydiegs
hello
I just want know if this USB DVB "K-World VS-DVB-S 300U" is compatible with Progdvb.
thank for your reply
best regards
  • Tue Mar 04, 2008 2:14 pm
roman
roman
Mon Apr 07, 2008 10:59 am
Kworld
#2 by roman
Dose anyone know if there is the possibiili that the ProgDVB is working properly with this USB SAT reciver Kworld USB DVB-S 300U ?
THX for any help
  • Mon Apr 07, 2008 7:11 pm
#3 by Prog
What problem you have?
  • Mon Apr 07, 2008 8:08 pm
roman
roman
Can I buy it ? Is worth it ?
#4 by roman
I do not know if should I buy the device from KWorld company ?
I do not know if the device will work properly with the software ?
I do not know if the ProgDVB and KWorld SAT reciver will cooperate with additional software ?
  • Tue Apr 08, 2008 8:51 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 3:54 pm
