TechniSat SS2 vista x64 drivers?
1 post
Porter
Porter
Sun Mar 16, 2008 8:55 pm
Ukraine, Lviv
Contact:
  • ICQ
#1 by Porter
hi.
I can`t run SS2 on Vista 64 bit.
I use last SS2 driver, last Prog DVB 5.xx
SS2 is instaled in Vista, I can see it like network card. But Prog DVB cant see it, can`t start devise. Seme on native soft from SS2.
Is any way to make it work on Vista x64???
Regards
  • Mon Mar 17, 2008 8:59 am
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 8:54 pm
