ProgDVB and EVR
How can i Use EVR with ProgDVB?
I Went at Video Render (Progv5) but mine is Lock at VMR-9!!!
How do I Change it??
I using SS1 at HM, i don't think is that the problem??
my stuff:
1st PC: Core2Quad (2.5Ghz), ASUS Proximus Extreme (1007), 2GB ram, nvidia 9600GT*2 (PCIe) + 7950GX2,
< 1stDVB - TechnoTrend S2300 + C.I. /Driver Technotrend 219h>
and < 2ndDVB - TechnoTrend S2300 /Driver Technotrend 219h>.
WinVista32 Ultimate. ProgDVB 5.x
2nd PC: AMD 4600+ X2 (2.51Ghz), GIGABYTE GA-K8NSC-939 ( F8 ), 3GB ram, nvidia FX5950ultra (AGP).
< 1stDVB - Hauppauge NEXUS-s/Driver Technotrend 219h>
and < 2ndDVB - Hauppauge NEXUS-s + C.I. /Driver Technotrend 219h>.
WinXP 32PRO. ProgDVB 5.x
3st PC: AMD 4200+ X2 (2.2Ghz), Asus A8n32-SLI Deluxe, 3GB Ram, Nvidia 9600gt 512mb (PCI-E),
<1stDVB - Hauppauge NEXUS-s /Driver Technotrend 219h>
and <2ndDVB - TechnoTrend S2300 + C.I. /Driver TechnoTrend 2.19h>.
WinVista 32 Ultimate, ProgDVB 5.x
LNB (13E,19E,39E,16E,42E,30W,1W,5E,26E,28E)
:oops: Thank you.
I test it with SM but i've got same error...like <pin...semething..error> and then Progdvb just hung up. Any way...I don't Use SM so..I'm Ok.
Thank you.
my stuff:
Hi,
I use XPsp3 + .NET 3.5 and ProgDVB 4.91.2.
When choosing the Enhanced Video Renderer in the 'Audio and video options' it says: "This renderer not supported. Change to VMR". What's the problem?
XP/sp2 after install net 3.0
i have also XP Sp3 and .Net 3.0....but no EVR (but i don´t miss it...)...only on my other PC where actually windows vists is running ....EVR is avivable
