Hi
I am using progdvb 5.13.07 to see the TDT, and I get on the right up corner a green legend that says:
Audio Track.
Input Description: 48000 Kz. Stereo 192 kbs mp2 (libmad)
output description: 44100 Kz, stereo 16-bit integer
Number of channels: 2
Current input bitrate: 192 kbs
Is it possible to get rid of it ?
And a curiosity. One of the screenshots in the manual shows a screen
where two channels are being displayed simultaneously. It shows three tabs, two with two channels and one that says 'All' with two little screens. Is that a special version ?
Thanks
Carlos
The 'legend' is not from ProgDVB itself, as ProgDVB does not send that data anywhere to.
The source of it must be the codec you're using.
And the OSD function used surely is it's internal one.
So check the properties / settings of your codec.
Probably the insertion of the parameters is caused by itself or it's host application.
Regarding the manual picture (should be this one:
http://progdvb.com/manual_img/sample.jpg ), no idea, as my Nexus won't allow PIP or multiple chzannels, due to no TS.
