При попытке поставить скин Skin2A.xskin (Dr. M. Nateghi) в версиях 5.14.03 и 5.14.04 возникает следующий эксепшн:
at IPDev.Skins.SkinForm.SetSkinObject(Type type, Type newDockFormType, SkinObject skinObject)
at IPDev.Skins.SkinForm.SetSkinObject(SkinObject skinObject)
at IPDev.Skins.SkinForm.SetSkins(String filename)
at ProgDvbNet.MainForm.(Boolean )
at ProgDvbNet.MainForm.(Object , EventArgs )
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
ProgDvbNet
Assembly Version: 5.14.4.0
Win32 Version: 5.14.04
EngineApiWrapper
Assembly Version: 1.1.0.9
Win32 Version:
msvcm80
Assembly Version: 8.0.50608.0
Win32 Version: 8.00.50727.42
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0DE06ACD/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.1.1
Win32 Version: 1.0.1.1
IPDev.Skins
Assembly Version: 1.2.15.0
Win32 Version: 1.2.15.0
ProgDvbNet.EPG
Assembly Version: 1.0.1.3
Win32 Version: 1.0.1.3
ProgDvbNet.resources
Assembly Version: 0.0.0.0
Win32 Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/ProgDVB/ru-RU/ProgDvbNet.resources.DLL
Accessibility
System.Design
System.Xml
System.Drawing.Design
enabled.
For example:
<configuration>
</configuration>
