hi
1 post
complicated_man001
complicated_man001
Mon May 26, 2008 4:42 pm
hi
#1 by complicated_man001
i have same problem with my new digitalrise pci card i can not find the modules if there is any shance to make my card work with progdvb. thank`s lot
  • Mon May 26, 2008 4:54 pm
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 4:53 pm
