Skystar USB2 and ProgDVB problem
Hi
I am using Windows XP Service pack 3 with a technisat skystar usb2 i just downloaded the latest beta drivers from technnisat site and installed the latest version of ProgDVB 5 from this site properly. But when ı select skystar 2 from the program and enable it The device could not be found error message recieved. Then I install the latest version of ProgDVB4 the same problem happened Later I change the driver versin to 4.4.1 (stable) release the same situation.
When I install the BDA drivers for skystar 2 usb version It worked bu the diseq is not working I have two setallites and I am get stuck in one of them...
I there a solution ? How can I use the normal drivers and progdvb without any problem?
Thanks
you have to select your BDA card in device options for the diseqc.
