not register thsource.ax in vista (help)
darkness
darkness
Thu Jun 12, 2008 5:18 pm
#1 by darkness
hi and gl
i am using windows vista 32 bit and i try register thsource.ax and creat the bat file (regsvr 32 thsource.ax) but I got error message: The module"thsource.ax"failed to load my dvb is twinhan 1020a and i am using skynet and i must register this file please help me.
tanks.
  • Thu Jun 12, 2008 5:34 pm
I think BDA driver is best way.
  • Sun Jun 15, 2008 4:54 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 5:41 pm
