Hi, sorry but my english is not so good but i try it, hope you understand me.
until today i have the ProgDVB Version 484 using without Problems. Last month some channels on Astra change their transponder and this transponder is not in the list of this ProgDVB Version.
So i try the new versions 494 and 515 cause they including this new transponders cause i dont know if or how its possible to import this list to an older version.
Both Versions, 494 and 515 have no problems by install, find the new channels immediately and start by the klick on ok.
In this moment the program minimize to tray icon. Audio is very well but no picture...if i set the mouse cursor to the tray icon for ProgDVB then it dissapears but the sound is going on. Sitting here since 3 or 4 hours and try everything but i have no more Idea. May be you can help me?
Nexus-S - A7V600 - AMD-XP2500 - 2x512MB Ram - Ati9250 - Windows XP-SP3 with all Updates.
thx a lot,
Michael
You must search problem sound and video on this forum, but problem sound and no video and video and no sound is continuing since version 5.14.x. A partial solution is using wave output for sound, but not direct sound, in this moment you can't use volume setting in ProgDVB.
A new transponders: you must manual edit file all.list or download file ???.ini
for relevant transponder and put in directory transponders.
If in HW mode, check device settings, activate software scaling.
However, you can stay with the old version, as you can find suitable up-to-date transpopnder lists at joshyfun.peque.org (once it's back online, maybe in some trouble right now).
Also possible, to install new ProgDVB into another folder and borrow.
Or in case, use your editor to update the old one. Format is quite easy, so add lines at the end, number them and after this correct the entries counter value above.
For HW mode onj your Nexus, new versions of ProgDVB have some limitations, like no HW playback on the TV out. This for stay with what you're satisfied with. For me it's 4.75, last of the old ones with a working plaback slider and accepting all recordings.
