Buying a card that works with ProgDVB - Pinnacle 450i works?
1 post
smoker
smoker
Sat Aug 16, 2008 3:54 pm
#1 by smoker
I'm thinking about buying this card:
Pinnacle Systems PCTV SAT PRO PCI 450I TV Karte intern
I have tried 2 cards in the past, I forget which ones. Both with poor results, one hardware would not work and second was really bad software.
So I want to be more sure of what I buy this time.
ProgDVB seems to be good software, so I just gotta find good hardware :)
Thx,
Smoker
  • Sat Aug 16, 2008 4:00 pm
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 5:41 pm
