how can i chang font in progdvb 4.83.2
i use the changer plugin but it dosnot work with this verion ..
i dont have skin editor .. i have only this three things
Elecard Registrator
GraphEdit
Uninstall
ProgDVB
Elecard Registrator
GraphEdit
Uninstall
ProgDVB
oud
Update your Changer plugin.
Changer3.x support all versions of ProgDVB.
http://www.fastsatfinder.com/download.h ... ger_plugin
Updated Changer plugin.
Changer3.2NET is compactible with ProgDVB 5.16.x (fixed option "text size")
