Pctv Sat 400i is not listed in the Device list.
pctv sat victim
pctv sat victim
Sun Sep 14, 2008 12:11 pm
#1 by pctv sat victim
Hello I have the following problem:
After I have installed the latest ProgDVB version my Pinnacle pctv sat 400i is no longer listed in the Device list. In my older version 4.xx it was listed and worked. Do you know any way to get ist listed ?.
Thanks for your help.
  • Sun Sep 14, 2008 12:16 pm
Try copy pinnacle.device from old ProgDVB to new.
  • Sun Sep 14, 2008 2:14 pm
pctv sat victim
pctv sat victim
#3 by pctv sat victim
Thanks my progdvb is now working :)
  • Sun Sep 14, 2008 2:31 pm
#4 by Prog
Please send me good module.
  • Sun Sep 14, 2008 2:38 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 7:46 pm
