Problem with hauppauge hvr 3000 and prog DVB
1 post
Ozzzzy
Ozzzzy
Fri Oct 03, 2008 8:28 pm
#1 by Ozzzzy
Hi all!
Ive bougt the hauppauge hvr 3000.
i used win xp since yesterday and installed vista x64
now ive got a problem with progdvb. if i choose the device with i want to
watch ---> Dvb/s Device...
i choosed it and it spams me full with errors that the device not started,
encoding errors etc.
can anyone help me? must i use plug ins and if yes why?
Ozzzzy
  • Fri Oct 03, 2008 8:34 pm
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 8:38 pm
