I have a USB DVB device "LW-UDVB-S" from Light wave that came with DVBPlayer program.
The device drivers being used is called "DM20S DVB ". And it is WORKING FINE for DVB player software
Iam not sure which driver with progDVB would be suitable for this card, as far i know i tried all including BDA driver and it failed to recognize.
I couldn't revert to the vendor www.lightwave.com.tw/tvtuner.html as his support doesnot exist and i couldn't reach there.
Is there any compatible device i can define this card as or is there any way i can get progDVB to use the same driver defined in system.
Kindly advice.
Best Regards,
Please create MODULE for newmi DM20S
#2Hello,
I also the de newMS DM20 box, it works perfectly with the program dvbplayer, but it is really too simple.
Several people have already asked for the DM20 MODULE because other BDA are not compatible.
So please, ladies and major ProgDVB heads home you can create it.
