SATELCO HDTV DVB-S2 problem with CI
zluke
zluke
Tue Nov 11, 2008 5:43 pm
#1 by zluke
i am not able to read CI with progdvb and this Satelco card.
When i try it the window shows 'waiting for data' but nothing happens.
any help?
Regards,
zluke
  • Tue Nov 11, 2008 5:45 pm
Try select KNC in settings->Device options. But I am not sure.
  • Fri Nov 28, 2008 10:39 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 8:38 pm
