ProgDVB closes with plug jfnofreeze
hi, this is the problem , when I try to open it, it shows the windows that progdvb is loading but then it closes, this is when I put the jfnofreeze plugin into the plugin's folder, when I
remove the jfnofreeze the ProgDVB opens normally, but is that I need this plugin because I have a nexus and without this plugin I was paralyzed the image constantly, what could be this??.
thanks gabriel
As far as I know, this plugin is only used together with another one for software decrypting.
And the freezing this one wants to correct, only comes from issues between the decrypting tool and ProgDVB, related with the Nexus / SS1 hardware and an American provider or two..
Issues like this are to be discussed on dvbn(dot)happysat(dot)org, anyway the place to find the authors of both plugins.
We don't talk software decrypting issues here at all.
And we are not responsible for any issues with 3rd party plugins, specially as the plugins API is publically available...
CLOSED
