Hello
I`ve just installed the last version of the progdvb but when I ran it, a message shows to me that says: "Either install the Elecard H.264\AVC decoder package, or if you would like to use a diffrent H.264\AVC decoder" I pressed OK, but when I choose any of the channels it shows that there is a good signal but nor video or audio are shown.
I`ve installed the decoder package that the message asked me to from this link:
http://www.elecard.com/products/product ... ogdvb-avc/
But also it did not work.
the old versions are working very well.
can anyone help me
thanks
Having a Problem with H.264\AVC
#3Actually - I'm new to progdvb (free edition) - but I'm having a similar problem with v6 ... it finds all the std uk dvb channels ... but whichever TV one I select (eg bbc1,2,channel4,five etc) it says "Either install the Elecard H.264\AVC decoder package, or if you would like to use a diffrent H.264\AVC decoder"... even though I didn't think these were H.264\AVC channels. Progdvb then becomes unstable - either hanging or crashing.
(also If I select a radio chanel with good signal - I get no audio sound.)
Probably not related - but I then installed arcsoft totalmedia and this worked fine (though very bloated
) ... I then tried progdvb again and it again complained of H.264\AVC channels - and crashed again after I tried modifying settings to point to some of the arcsoft codecs.
Any ideas... should I need to install/register any additional codecs to see standrd dvb tv channels or listen to radio?
>ProgDVB std total not support h264 channels. Only ProgDVB Pro.
I am using the free version... but the channel I am trying to see is BBC one in the UK... (but same result for all other freeview TV channels)...
If I look at channel protperties it has h264 not ticked... yet when I try to open channel it gives the error msg "install the Elecard H.264\AVC decoder package .... etc"
thanks for any help?
Hi,
Hey I was just to open same thred about this problem!
I've got just the same problem. I just CAN'T SEE any channel.
Just black picture! And with any codec and I used, it still get my the same error window:
The problem is that i've got the Progdvb Pro version (registered - ok)
I am using a Nexus card at softmode (but to my other 2 computers works Perfect) I don't know what's the problem with this one!!
I had install K-lite codec Mega pack (just like my other computers) I have install all the Elecard pack but still the same problem!!
Does anyone has any idea?
(This is a fresh install of Windows Vista ult.32 for more see my third computer)
PS.
I will try to record some Pid and then upload them
PS.
my stuff:
1st PC: Core2Quad (2.5Ghz), ASUS Proximus Extreme (1007), 2GB ram, nvidia 9600GT*2 (PCIe) + 7950GX2,
< 1stDVB - TechnoTrend S2300 + C.I. /Driver Technotrend 219h>
and < 2ndDVB - TechnoTrend S2300 /Driver Technotrend 219h>.
WinVista32 Ultimate. ProgDVB 5.x
2nd PC: AMD 4600+ X2 (2.51Ghz), GIGABYTE GA-K8NSC-939 ( F8 ), 3GB ram, nvidia FX5950ultra (AGP).
< 1stDVB - Hauppauge NEXUS-s/Driver Technotrend 219h>
and < 2ndDVB - Hauppauge NEXUS-s + C.I. /Driver Technotrend 219h>.
WinXP 32PRO. ProgDVB 5.x
3st PC: AMD 4200+ X2 (2.2Ghz), Asus A8n32-SLI Deluxe, 3GB Ram, Nvidia 9600gt 512mb (PCI-E),
<1stDVB - Hauppauge NEXUS-s /Driver Technotrend 219h>
and <2ndDVB - TechnoTrend S2300 + C.I. /Driver TechnoTrend 2.19h>.
WinVista 32 Ultimate, ProgDVB 5.x
LNB (13E,19E,39E,16E,42E,30W,1W,5E,26E,28E)
