dm04 remote control?
Violent Kain
Violent Kain
Fri Jan 02, 2009 5:34 am
#1 by Violent Kain
Hi, is there any way(module) to get the remote control working?
  • Fri Jan 02, 2009 5:36 am
christiw
christiw
Thu May 27, 2010 7:20 am
Re: dm04 remote control?
#2 by christiw
You can try Infrared remote control module for Windows. The software enables you to create different scripts for different applications, so you can fix the same buttons to different functions according to what programs are running.
r4i sdhc
  • Thu May 27, 2010 7:57 am
Return to “Modules”
Вы мне логи крашей присылали?
  • It is currently Sun Jun 28, 2026 1:03 am
