Hello, i just broght the last version of ProgDVB 6.03.03 and i would like to know if any of you had solved this issue:
Can i set on a select Channels a fixed Aspect ratio to 16:9 ?
There is a way to set by default all 4:3 source set to 16:9 and leave
source 16:9 as is ?
Every time i change channel from different Aspect ratio source, i got on my 16:9 Monitor a "square" Movie for 4:3 and "rectangular" for 16:9 EVERYTIME....
What can i do ?
I tried to change my nVidia Decoder setting as i did on my last DVB software, but i can't reach it using DVBProg.
Any suggest ?
Thank you very much
Thanks, you are right.
I tried that settings and it seems good, when watching Video 4:3 with Horizontal Black bars on upper and bottom of the video.
But, when i watch a 4:3 Video when Video fullfill the whole 4:3 aspect ratio, i miss part of the Video up and bottom using letterbox.
I think should be used the setting used pressing "Aspect Ratio" V Key for all the Channels i choose.
Maybe on next revisione of the Software
No more news about it ?erosoft wrote:Thanks, you are right.
There's no any chance to Set a 16:9 Aspect Ratio for a selected Source(Channel) ? I just want to avoid to Press "V" on keyboard anytime i watch a 4:3 Channel.
Thanks anyway.
#6What i need has been implemented on Rev. 6.03.04.Prog wrote:ProgDVB have zoom, radio and letterbox settings. What you need more?
Now im able to change aspect ratio on single channels and this settings are stored by the application as default.
This is what i were looking for...
Thank you very much.
