can v4 and v6 be installed the same time
DoD
DoD
Fri Jan 16, 2009 6:04 pm
#1 by DoD
can i use both versions on the same machine :idea:
  • Sat Jan 17, 2009 8:26 pm
SiLencer
SiLencer
Fri Nov 03, 2006 12:10 pm
#2 by SiLencer
yes ...no problem ..if installed in different folders...
  • Sat Jan 17, 2009 8:34 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 8:51 pm
