Which Card?
1 post
Nick.123
Nick.123
Wed Jan 21, 2009 7:18 pm
Which Card?
#1 by Nick.123
Hi, Can anybody suggest the best cable card to use with progdvb that i can buy from the uk.
Thanks
  • Thu Jan 22, 2009 9:34 pm
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 7:47 pm
